over heating need help bad!!
Old Mar 31, 2008 | 05:47 PM
RAPTORPIT's Avatar
RAPTORPIT
Hi all, I have a 03 f350 drw long bed. In november the water pump was replaced. Along with the over flow pressure jug. I just replaced the thermastat, still have the same problem.
When I start the truck and start driving it the temp creeps up to normal. I do not get any heat through the heat vents in the cab. I will get heat coming out when the truck starts to climb past normal temp.
I can no put my foot in the throttle and drive normal, the truck will jump up to the red. I take my foot out of it and the temp drop's. I am getting heat out of the vents the whole time now. The cluch fan seems to be working, just fine. I have checked between all the coolers and nothing blocking the air flow. What do you guy's think??? I need help, NO MORE warranty. Thanks RP
Old Mar 31, 2008 | 05:57 PM
OZX1's Avatar
OZX1
Go here and read-up https://www.motorcraftservice.com/pu...2/S3OS330L.HTM
Old Mar 31, 2008 | 06:27 PM
RAPTORPIT's Avatar
RAPTORPIT
Thanks, for the help. I have read all that info still dosen't answer my question. Guess i'm going to the dealer. I tried alot of that to day.
Old Mar 31, 2008 | 06:34 PM
brickie's Avatar
brickie
Plugged oil cooler is my guess.
Old Mar 31, 2008 | 08:52 PM
OZX1's Avatar
OZX1
So none of the troubleshooting guides were of any help? that's the same stuff that fords' going to use to diagnose the issue... You may want to double check some items...
Old Mar 31, 2008 | 08:59 PM
RAPTORPIT's Avatar
RAPTORPIT
I still don't under stand why I'm not getting any heat in the cab until it gets to warm, close to very hot!
I'm missing something here? I just wonder if the new water pump's shaft broke, or if I need to really burp it. I was hoping some one else might of had this problem, to may be help me out any ideas are welcome!! thank's RP
Old Mar 31, 2008 | 09:17 PM
brickie's Avatar
brickie
Your oil cooler is plugged. The coolant is not circulating you will take out the egr cooler next.IMHO
Old Apr 1, 2008 | 11:28 AM
BowTieHatr's Avatar
BowTieHatr
no heat = water pump.
Old Apr 1, 2008 | 12:28 PM
kkhawes's Avatar
kkhawes
agree with bowtie i had a new pump installed and the impeller broke away from the shaft around 10,000 miles. would do the exact same thing letting you drive short distance and then heat up and take a while to cool down.
Old Apr 1, 2008 | 01:25 PM
skoveng's Avatar
skoveng
Are you just going by the gauge? Is it reaching the point where it is blowing out?
Old Apr 1, 2008 | 02:21 PM
brickie's Avatar
brickie
Well there you go you got a bad water pump out of the box.
Old Apr 1, 2008 | 02:50 PM
RAPTORPIT's Avatar
RAPTORPIT
Thank's for all the help every one. The dealer just called me, They had been working on my truck since 8 this morning. I called at 2pm to find out what was up, and it's a cracked propeller shaft, on the new water pump, installed 4,000 miles ago glad it was covered under warranty.
Old Apr 1, 2008 | 02:56 PM
OZX1's Avatar
OZX1
As if there was ever a doubt...
Old Apr 1, 2008 | 04:52 PM
Kep4's Avatar
Kep4
Jäger
Thank's for all the help everyone. The dealer just called me, They had been working on my truck since 8 this morning. I called at 2pm to find out what was up, and it's a cracked propeller shaft, on the new water pump, installed 4,000 miles ago glad it was covered under warranty.
Go to post #8 and click this= in the upper right corner, then you can tell BTH "Thank You!" directly.
Old Apr 1, 2008 | 07:51 PM
brickie's Avatar
brickie
Rep points given. Good call BTH!
