1994 B-2300 - Starting problems
Old Mar 31, 2008 | 04:11 PM
Into The Wild's Avatar
Into The Wild
Have had a problem with my 1994 B-2300 pickup for a while now. In the winter, when the temperature hits below zero fahrenheit, I plug my truck in for obvious reason. I often have trouble starting it, though, when it is plugged in. The engine will turn over a fire up for a second and then choke off and die no matter what I do. After cranking it for a long time (and destroying my starter), it eventually catches. There is no problem when it is not plugged in except for the damage not plugging in causes to the engine and the wear on the battery (caused in any case). At the same time, the fuel gauge has read zero for a while. The fuel gauge used to freeze in winter (alongside starting problems) and work properly in summer but it is now useless. Can these two problems both be related to a drop in fuel pump performance? Fuel filter, spark plugs are new and there is no water in the fuel lines.
Old Mar 31, 2008 | 07:50 PM
crazypaw's Avatar
crazypaw
Wink
Welcome to FTE Into The Wild,
Definately start with checking your computer codes.
Also goto for how to do's:
https://www.ford-trucks.com/forums/1...formation.html
Last edited by crazypaw; Mar 31, 2008 at 07:56 PM. Reason: add keno's tech address
nuttntoit
15
Mar 31, 2021 02:53 PM
pvatki
15
Sep 20, 2009 08:46 PM
Sholou
34
Apr 11, 2006 10:45 PM
1994_F150_302M
71
Oct 3, 2005 04:05 AM
nightshifter
16
Jun 25, 2004 06:09 AM
