Aerostar Ford Aerostar
Side Door Roller Bearing Source
Old Mar 31, 2008 | 12:21 PM
tom_foreman's Avatar
tom_foreman
Has anyone found a source (besides the dealer) for this part? I've never found one in good shape at a junk yard.
Old Mar 31, 2008 | 01:28 PM
99f350sd's Avatar
99f350sd
I don't think there is another source.
Old Mar 31, 2008 | 02:32 PM
aerocolorado's Avatar
aerocolorado
ACE Hardware - ...........don't laugh. I matched the old with a new one from there. I had to drill and tap the old post to install it, but it works just fine. Much better than the old, worn one.
Old Mar 31, 2008 | 02:34 PM
tom_foreman
I read where you did that a while back. I wondered how well it held up. You don't remember any of the details on the part do you?
Old Mar 31, 2008 | 02:57 PM
cookkd's Avatar
cookkd
Tom,
Sometime back there was a post that had the link to a source for this part. It is a Ford dealer in Oregon or Washington. Real reasonable prices. I ordered one from them at the time, but can't recall where/who it was.
Maybe the author will see this and post the link again.
Klaus Cook
Houston, Texas
Old Mar 31, 2008 | 04:14 PM
aerocolorado
Its been several years of use now and it rolls back and forth almost effortlessly-just oiled the rollers yesterday.
The bearing was just a standard steel, sealed, ball bearing, with perhaps a 5/16" bore and maybe 3/8" wide. Just make sure it is at least the same height or even a tad higher than the worn one, else your door will contiue to drag on the rubber door seal/scuff plate.
I have a '91 and on those years the entire lower arm w/bearing had to be replaced as the bearing is riveted on. I removed the arm, drilled out the rivet (a knurled affair, preventing just twisting it out) and then tapped the hole for a new shoulder bolt. I used some permanent threadlocker on the bolt (sleeve retainer) with no problems to date. Since the original used a nylon roller and the replacement was all steel I worried about excessive noise but this has not been an issue at all. I cannot tell any difference.
dw200
Apr 12, 2013 11:40 PM
85lebaront2
May 7, 2011 10:52 PM
orng1
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Oct 13, 2008 01:09 PM
landl
Alternative Fuels, Hybrids & Mileage
Apr 8, 2008 03:33 PM
enduringexplorer
Sep 6, 2005 06:48 AM
