Rebuilding the 4R100
The 4R100 is a sorry transmission at best. Even though it is based on old school design in the interest of weight savings a lot of parts that should have been steel and brass were replaced with aluminum and plastic. Plus the piggy backed electronic controls seem to confuse the trans more than it helps it. Unfortunately mod engines in big trucks don’t have much choice. These tranies can take the load that they are rated for but it can not take a shock load. As long as the load is gradually put on the truck it will be ok. But neutral drop it or try to rock out of a mud hole and it starts to get a little stressful. I know this is a little more than you ask but I want you to know what you’re up against. Most of the quick, cheap shift kits on the market are a waist of time. If you’re going to spend the money do it right and get one from one of the specialty shops.
E4OD and 4R100E Performance Products
Again, listed but they talk more about the E4od, but maybe a source of info if not hard parts.
TCI - Ford E4OD / 4R100
Good luck.
