1978 - 1996 Big Bronco
ABS on my 93'
Old Mar 30, 2008 | 09:32 PM
RA81222's Avatar
RA81222
ABS on my 93'
I have posted about this before and have just been ignoring the ABS light, but would like to figure it out.Code I get is "17" when checking it.I tried following troubleshooting from Autozone site and it tells me to install a"Pinout Box" what ever that is or where to install it?No way to follow there voltage and continuity checks without this the way I see it.Some things I can check such as relay, voltage to fuse and fuse itself.Also, is there a way to reset the code? My father repaired his Chevy ABS and was able to jump some pins on his test conn. and clear his code.Any help would be appreciated.
