Quick Egr Q's
Old Mar 30, 2008 | 05:31 PM
guitarnik's Avatar
guitarnik
Quick Egr Q's
'90 f250 351. i plugged my egr and removed the plumbing. what wires should connect to tell the computer that there in nothing wrong or that the egr is closed all the time
Old Mar 30, 2008 | 09:02 PM
MrG4x4's Avatar
MrG4x4
There are three wires to the EGR position sensor. Orange/White which should be power, about 5v. Black/White which should be ground. Brown/Light Green which should be the return signal to the computer. If you put a 100 Ohm resistor between the Orange/White and the Brown/Light Green you should be telling the computer the EGR is wide open. If you put a 5000 Ohm resistor between the these two wires you will be telling the computer the value is closed.
Old Mar 30, 2008 | 09:12 PM
Noneshere's Avatar
Noneshere
I would ignore the "code" alltogether.
It should not be causing a light on the dash to come on.
I don't run "another problematic" EGR either. They have a leaning effect to the motor at highway speeds . Thats how they get a lot of the "Fuel economy" out of cars today.
A cheap rendition of nitros , with out the compression increase of a freezing, inert(non-flamable), gas expanding, as nitros dose.
The code will always show , just ignore it.
If you do have a check engine light..........Look at a new O2 sensor
Old Mar 30, 2008 | 09:15 PM
MrG4x4's Avatar
MrG4x4
I would tend to agree with Noneshare as well.
Old Mar 30, 2008 | 09:19 PM
Noneshere's Avatar
Noneshere
MrG4X4 dose seem to know his electronics very well
Old Mar 30, 2008 | 10:21 PM
Conanski's Avatar
Conanski
The problem with disconnecting the EGR and not telling the computer the valve is closed is that it will still add the ignition advance called for in the EGR tables, so the motor will get detonation prone in a short period of time.
Old Mar 31, 2008 | 12:14 PM
stangbanger's Avatar
stangbanger
cant you just delete the egr all together and let it be /?
-Randy
Old Apr 1, 2008 | 07:57 AM
muddyford911's Avatar
muddyford911
yes you can. but you HAVE to find a way to let the PCM know that the EGR valve is shut all the time. go to fordfuelinjection.com theres an EGR eliminator there, and you can also read up on the EGR system and find out how it really works.
Old Apr 1, 2008 | 09:11 AM
9299Fords's Avatar
9299Fords
EGR delete link
RJM Injection Tech » EGR Eliminators
Old Apr 1, 2008 | 06:00 PM
stangbanger
helpful thanks!
Old Apr 1, 2008 | 07:41 PM
stangbanger
when you remove the egr stuff can you just leave the smog pump in tack and use a short belt to bypass it, and let it and its plumbing just be as is?
-Randy
