Useful Formulas and pointless numbers Youre welcome!
Mar 30, 2008 | 06:19 PM
just another Rockwell looser
Quote:
Originally Posted by STGFordCrazy04
Here is Bobby Longs (longfield axles) axle breaking machines results I robbed off pirate.
PRODUCT ................................ FT.LB. TORQUE / DEGREE TWIST
Yukon 4340 Dana 60 35 spline short side axle...12,000 / 130
Stock Dana 60 35 spline short side axle.........8,300 / 35
Yukon 4340 Dana 44 30 spline short side axle....5,800 / 35
Stock dana 44 30 spline.........................5,000 /35
........lame!
Mar 30, 2008 | 06:23 PM
Freeeed,
Hes picking on me again!
quadzjr =
Mar 30, 2008 | 06:28 PM
not the entire post......just the part where d44 yukons suck....
well they work good for me.....bogged the chit out of it today....
Mar 30, 2008 | 06:30 PM
They dont suck......just not as good as stock 60 stuff.
Im waiting on pics
Mar 30, 2008 | 06:35 PM
Im waiting on pics
you said that came from longfield? may be biased?
yukon must be lying then......they claim same as stock d60.....
Mar 30, 2008 | 06:40 PM
I dont think he was biased. Pretty cool machine.
Mar 30, 2008 | 07:00 PM
thats a pretty sweet little setup there. wish i had that job, get to break chit all day and just write down a couple numbers. thats the life
Mar 30, 2008 | 07:03 PM
If you read the article Bobby tested a longfield CV for a D60 and it maxed out and started bending the machine. 19000ft lbs and 100* of twist
Mar 30, 2008 | 07:28 PM
What kind of axle U-joint do you couple to that?
Mar 30, 2008 | 07:36 PM
Quote:
with what? a cv?
CVs do not have a U Joint. Its basically a ball and socket with ball bearings inside. Very strong and smoother function with less upkeep. They will also handle more rotational stress at max angles than U joints. I think these are rated at sharper turning angles than a normal 60 can turn.
Longfield CVs are uber cool but are $1850 for a set! and thats $6-700 more than the very best (superiors and ctms) axle/ujoint combo you can buy.
Mar 30, 2008 | 08:10 PM
I missed the CV part. Is that the same as a closed knuckle?
Mar 30, 2008 | 08:12 PM
No a closed knuckle still has a u joint inside but they look similar.
Mar 30, 2008 | 08:22 PM
Street Queen to the extr3m3
i want pics!!!!!!!
Does this change the placement of the for sale sign?
Mar 30, 2008 | 08:25 PM
OK, thanks for clarification. Thats some serious front axles.
Mar 30, 2008 | 09:08 PM
Quote:
Originally Posted by Truckin4life
i want pics!!!!!!!
i'll see if i can get them.....no, its still for sale...
