i'm putting a 7.3l w/ a e4od in a 77 f250. im taking the harnesses from the 92 f250. need to know how the trans harness and tcm are wired in to the truck and the wait to start, water in fuel lights are wired in i just need some diagrams. let me know
well its a 92 f250 2wd super cab. i have the ford evtm's from the ford service info cd's but they are absolutely archaeic and i can't understand them, all i need is a schematic of the engine harness, transmission harness and where they go inside the truck (pcm, tcm)
i was at the junkyard today, pulled a black box (one plug) from behind the glovebox (metal) and a small plastic module under the steering column with two plugs both had a couple wires that matched the trans harness, im putting this power plant in a 77 f250
