1978 351M Advice
Old Mar 30, 2008 | 01:06 PM
husker's Avatar
husker
Sounds like you should fix the distributer/vac advance issues before changing a lot of other stuff. I have 400 that I changed the heads on because of a miss and I checked the firing order a number of times. I still screwed up and had two plug wires crossed and even after the heads were changed I still had a miss. Fixed the plug wires and it ran like a champ. The heads/valves I pulled were in bad shape, but that wasn't my main problem.
You might also post up on the 335 engine forum for the "experts" over there to help out on the issues you have.
Good luck.
Old Mar 30, 2008 | 01:44 PM
Mil1ion's Avatar
Mil1ion
The timing on this engine can be anywhere from 6*-14 *
It depends on the EXACT engine ID.
You can see the specs on this page of mine.
http://mil1ion.clubfte.com/78Calibra...e-upSpecs.html
I come up with a calibration code of 7-72-R11 which has a timing setting of 14*BTDC
Have you checked the vacuum advance for being seized or having a broken diaphram ?
You definitely have a vacuum problem
Old Mar 30, 2008 | 02:37 PM
1967bird's Avatar
1967bird
Working on the truck now. I'll post some findings in a little bit.
Old Mar 30, 2008 | 02:48 PM
Bdox's Avatar
Bdox
I think you would be wise to invest in a good dynomometer tune-up. That way you will isolate problems and get the best out of what you have.
You could easily have a problem with cam timing or something simple.
They can recurve your distributor and determine the dynamic timing that is optimum for your truck.
Old Mar 30, 2008 | 05:10 PM
fatherdoug's Avatar
fatherdoug
I can't answer the differences in springs from F-250 to F-350. I only know that Ford did not manufacture an F-350 4X4 until the 1979 model yaer.
Old Mar 30, 2008 | 06:45 PM
LxMan1's Avatar
LxMan1
Something is wrong in the distributor if it starts missing with the advance hooked up.
Also, it should have ported vacuum to the dizzy, not manifold vacuum. It should not advance until you open the throttle.
Old Mar 30, 2008 | 07:06 PM
1967bird's Avatar
1967bird
Ok. Spent the better part of the day checking:
1) Spark plug wiring - checked out good, no crossed wires.
2) Distributer vac. advance - very stiff from no use. Used some PB blaster and got moving freely again. Verified diaphram was good with no leakage using a hand pump.
3) Reassembled dist. and went to check the timing.
4) Loosened dist. holdown.....dist. was frozen solid....couple of hours later I got it completly freed up.
5) Set the timing to 10 degrees and the rpm at 700. Set the idle air mixture screws equally on the carb.
6) Idle is fairly smooth, response is decent now and the vac. secondaries will open under WOT. Vacuum at idle is 16 inches.
7) At this point, everything seems decent enough to try connecting the vac. advance on the distributer again.........No luck....engine immediatly starts to miss and run rough. Timing goes to something like 32-34 degrees best I can tell when the timing light actually fires.
Old Mar 30, 2008 | 07:11 PM
1967bird's Avatar
1967bird
The vacuum advance on my distributer is ported to a vacuum line off of the Edelbrock carb. Is this the correct location? Keep in mind that it also has a Edelbrock Performer manifold as well.
Old Mar 30, 2008 | 07:22 PM
luckyranger79's Avatar
luckyranger79
Is the hose going to the spark advance pulling vacuum at idle? If so, then it might be hooked to the wrong port on the carb. Worth a shot.
Old Mar 30, 2008 | 07:32 PM
1967bird's Avatar
1967bird
Yes it is. I am going to look for a manual now for that carb.
Old Mar 30, 2008 | 07:43 PM
1967bird's Avatar
1967bird
Ok. The manual says the line should connect to the passenger side port (right now it's connected to the driver's side). Well, I give that a try next. Thanks.
Old Mar 30, 2008 | 07:48 PM
husker's Avatar
husker
Sounds like you made some real progress. Congrats on getting the dizzy to work better.
Old Mar 30, 2008 | 10:10 PM
  #28
luckyranger79
good deal
Old Mar 31, 2008 | 12:03 AM
  #29
85e150's Avatar
85e150
Originally Posted by 1967bird
To 85e150six4mtod The timing is set to 8 degrees. The one thing I discovered this morning is the vac. advance going to the distributer is blocked off. When I reconnect it, the truck seems to run on about 5 cylinders, warm or cold. It so bad that my timing light triggers about a 1/4 of the time. The engine pulls a steady 14 in of vac. at idle. What gives?
I was talking about cam timing. 400s used a retarded timing which really dogs them. Not sure if your engine suffers the same fate.
As for your vacuum advance, it sounds like the diaphram in the distributor is bad and connecting the vac adv gives you an instant vac leak.
Old Mar 31, 2008 | 12:15 PM
  #30
Mil1ion's Avatar
Mil1ion
He stated the engine was rebuilt back to NEARLY stock condition by the P/O.
What does this mean ?
Did he use a retarded gear or a 3 key way gear and set it straight up ?
