Light staying on
Old Mar 29, 2008 | 07:42 PM
rmalottwtes30's Avatar
rmalottwtes30
Light staying on
When I have all my lights off the rear lights stay on, there not that bright but very faint light. When I turn on my running and head lights everything works fine except that the rear driver side turn dont work on the rear, but with the lights off it works. Do I suspect a bad socket? or wiring? or my column since its out of a gasser, and mine is a diesel?
Old Mar 29, 2008 | 08:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
My guess is you are looking for a bad ground.
Bed mounted on rubber mounts, needs a frame to bed ground.
Tail light housings are plastic, so they need a ground wire from the bulb to the bed.
Old Mar 29, 2008 | 08:15 PM
rmalottwtes30
So a bad ground will make the lights stay on? I always thought the opposite...Well I guess Ill check it all out tomorrow.
Old Mar 29, 2008 | 08:41 PM
Dave Sponaugle
Automotive wiring is a bit funny.
Current that would be going to ground through the ground wire can backfeed through some circuits and light bulbs very dimly.
