transfer case
Old Mar 29, 2008 | 10:53 AM
karlkye's Avatar
karlkye
transfer case
where can i find visaul of different transfer cases?
Old Mar 29, 2008 | 11:08 AM
uncle.stosh's Avatar
uncle.stosh
Maybe a long shot, but if you Google "transfer case identification" you will get a wealth of information including:
http://www.venturesparts.com/Ford%20...ase%20Page.htm
Old Mar 29, 2008 | 11:21 AM
karlkye's Avatar
karlkye
which one is better 208 or bw? thanks alot
Old Mar 29, 2008 | 02:42 PM
Franklin2's Avatar
Franklin2
Borg Warner 1345 is supposed to have a wider chain than the 208.
The older 205 has no chain though, just gears, so it's even heavier duty. But it's cast iron and heavy.
And I also found out all these cases have different linkage setups and different overall lengths. If you are building something from scratch, that doesn't matter much. But if you are swapping, then linkage fitment problems and driveshaft length modifications come into play.
