uploading pics...
Old Mar 29, 2008 | 07:37 AM
redfire42's Avatar
redfire42
Question uploading pics...
I was trying to upload some pictures to my gallery hoping I could post some pics but everytime I get to the 'edit gallery' to upload I get an error and it about shuts my computer down. I didn't know if there was something wrong with the site in this area or if it could be my poor ISP connection. Dial up does stink at times Anyone else run into any problems?
Old Mar 29, 2008 | 08:04 AM
jdecker88's Avatar
jdecker88
If it is the security warning I always close it and never click yes or no. It use to do the same thing to me and lock up my internet.
Old Mar 29, 2008 | 08:07 AM
redfire42's Avatar
redfire42
it said something like signiture warning and it locked up everything no matter what. I almost had a picture uploadd then BAMM lock up.I don;t think its an ISP issue.
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Jeremy, I just tried to edit my gallery and it locked up on me. I will keep trying and see if I can get past this.
EDIT: I did like Justin said and it worked. I would always click yes on that before and never had a problem.
Old Mar 29, 2008 | 08:09 AM
megawatt00's Avatar
megawatt00
I ran into this problem on this site. It has to do with the java program. I uninstalled java and was ok from there. If you need me to help with the uninstall let me know and I'll go through it with you.
Old Mar 29, 2008 | 08:13 AM
redfire42's Avatar
redfire42
ok I will try it again and report back. Thanks guys!
Old Mar 29, 2008 | 08:17 AM
jdecker88's Avatar
jdecker88
Good to see it works Rick. I have noticed the site has started to crash more often, it got me a few times yesterday.
Old Mar 29, 2008 | 08:18 AM
megawatt00's Avatar
megawatt00
jeremy did your computer shut down or just your web browser?
Old Mar 29, 2008 | 08:31 AM
miller_feed
That was the first time in a long time it locked up on me. I had to shut it down from the Task Manager. It did bonk evertime I clicked the mouse. Hope it don't get worse.
Old Mar 29, 2008 | 08:32 AM
redfire42's Avatar
redfire42
my web browser shuts down along with disconnecting me. Just did it again while uploading. I just might be an ISP problem. I have dial up and cann't get anything else where we are at other then comcast and that would rock us $60 a month. What you said worked though about just closeing the security screen. Guess I just don't load any pictures for everyone to see. I will keep working with it and get more Peed. thanks again for the help.
Old Mar 29, 2008 | 08:33 AM
redfire42's Avatar
redfire42
I did have an error trying to get on FTE last night. Wouldn't let me on for about an hour.
Old Mar 29, 2008 | 08:41 AM
megawatt00's Avatar
megawatt00
I had that problem on FTE last night also. Your up loading pic problem is exactly the same that I had. This is what I did to fix it:
go to start menu..click on control panel...click on add\remove programs....give it a little time to populate the list. uninstall java not the run time enviorment. that's what I had to do. good luck!
Old Mar 29, 2008 | 08:53 AM
redfire42's Avatar
redfire42
OK now I am not good with computer programming. I don't see a jave but I see a js2e runtime environment 5.0 update 6? Is that what you said not to uninstal? Other then that, thats all I see.
Old Mar 29, 2008 | 10:13 AM
megawatt00's Avatar
megawatt00
Jeremy try and uninstall that one. I check my office computer and that's not on there. when i looked before i was on my daughters lap top. This site uses a java applet to allow you to drag and drop pics. I perfer to use the conventional browse button. Sorry if I confused you earlier.
Old Mar 30, 2008 | 08:46 AM
redfire42's Avatar
redfire42
Thanks for the help I think I got it now.
