Front end questions
Old Mar 29, 2008 | 02:31 AM
wilmac150's Avatar
wilmac150
Front end questions
Hello,
M '80 F150 4x2 longbed wanders alot when driving. Mostly when going straight (or at least trying to). Turning is no problem, and bumps don't seem to be a problem either. It has 90k miles, and tires are new, shocks look to be OK.
What should I look at with the front suspension??
Slainte'
Old Mar 29, 2008 | 03:53 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Play in the;
Ball joints
Tie rod ends
Pitman arm to drag link
Steering box
Old Mar 29, 2008 | 06:58 AM
wilmac150's Avatar
wilmac150
Thanks. Now to check em
Old Mar 29, 2008 | 08:19 AM
ri_truck_guy's Avatar
ri_truck_guy
If the things already listed check out ok, then check the I-beam bushings (also called axle pivot bushings), radius arm bushings, and the rubber steering coupler (also called a rag joint) where the steering shaft connects to the steering box.
