I would like to improve the turning radius on my truck. Its an 89 f-250 with a dyna trac 60 front axle. The previous owner had the aftermarket axle installed and its a little bit wider than stock. (my front tires stick out about an inch further than my rear ones) I am thinking this is why my truck turns so poorly. I mean it is very hard to pull into a parking spot or make a turn on down town streets. I will soon be using it for my business to pull a trailer and really need to correct this problem. I was thinking maybe a drop pitman arm might help the situation since it seems to sit higher than stock. Any suggestions?
The stock axle probably won't be much better. I have the f250 with the stock IFS (4x4) and the thing hardly turns at all. My buddy with the same year f350 with a monobeam can turn on a dime (for a full size truck), but the axle chews up the front tires... You could swap it with the stock monobeam axle....
Well I wasn't really thinking about swapping axles, I was hoping something in the steering geometry could be corrected. Actually it should be the same axle except for the width. The arm (not sure what its called) coming off the pitman arm is at a huge angle. Thats why i thought a drop pitman arm might straighten it out a little and give me some more range. i'll take a picture post it later.
If you shorten the steering arms on the front spindles, you will have more rotation of said spindle for a given amount of tie rod/pitman arm movement, and if there is enough clearance between the tires/frame and the crosslink/rods and the various chassis components, you can increase your turning ratio that way.
Truck bits are cast iron - fun to cut and weld as compared to other materials.
I did this on my 1993 Continental - the spindles were cast aluminum thus much easier to cut off the arms, shorten, then TIG weld back in place. Noticably decreased the turning radius, though my purpose in doing this wasn't specifically to decrease turning radius, but instead make the front end more sensitive to steering wheel movement. Seemed to be less work (at the time) than engineering a different steering rack ratio in a car with absolutely zero aftermarket support of any kind.
Intresting... I think I have plenty of room between the tires and spings, it sounds reasonable, but I don't know how safe that would be. I didn't think cast was very easy to weld.
