injectors?
Old Mar 28, 2008 | 06:56 PM
tim4.9's Avatar
tim4.9
injectors?
i have a 96 4.9l and i want to install bigger injectors. the ones in there now are stock 15lbs and i want to up grade them to a accel 17lbs injector. would i have to change my fuel pressure regulator to an adjustable one.
Old Mar 28, 2008 | 07:02 PM
Silver Streak's Avatar
Silver Streak
The search function is a glorious thing. On a 96 with mass air you will probably need to have the MAF calibrated to the size of the injectors.
Old Mar 28, 2008 | 07:16 PM
tim4.9's Avatar
tim4.9
i have tried to find an aftermarket maf but failed to find one at all for a 4.9l
Old Mar 28, 2008 | 11:35 PM
Silver Streak
I would compare the stock part number to one for a 5.0 or 5.8. If they are the same you could use an aftermarket MAF for either of those.
