460, starts hard cold?
i swapped a nissan pathfinder i had for an 84 f350 2wd crewcab today. has a 460, and auto tranny, 150,000 miles. it runs good, aside from a slight " stumble" or " hesitation" if you stomp the pedal to quick. oil pressure is good, comes up to temp ok, has pretty decent power. my only issue is when it's cold it tends to start hard.cranks and cranks, starts to catch. on and on. finally when it starts, let it warm up, runs good, shut it off, starts right back up. anyone have any ideas ?????
Fuel pump(s) not running when cranking the engine. You can test it by jumpering 12 volts to the rear small terminal on the starter solenoid and you should hear the pump(s) running. Then check the float levels ( sounds like they are low) and the accelerator pump (sounds like eithe a shot fuel shot or none at all).
bear wrote -" Fuel pump(s) not running when cranking the engine. You can test it by jumpering 12 volts to the rear small terminal on the starter solenoid and you should hear the pump(s) running."
it's carburated bear, is'nt it a mechanical fuel pump?
bear wrote - "Then check the float levels ( sounds like they are low) "
the guy i got it from said the carb was just rebuilt... so you may be onto something there
bear wrote - "and the accelerator pump (sounds like eithe a shot fuel shot or none at all)."
a short fuel shot or none at all, hmmm, maybe he did'nt rebuild everything, very possible , will look into that.
dirt racer wrote - "With that many miles you might want to check out your spark plugs too. Excessive gap and it would be hard to start. Maybe a good tune up. "
will do
bear it crank pretty fast so i dont think it's that. gonna look into float levels and plug gap today and go from there, thanks
will do
will do
will do
wow, that's good to know bear. i fooled with it a bit earlier. when looking down throat, i open up throttle and nothing squirting, so i'm thinking accel pump.
question.... the electric pumps...... they either work... or they dont, correct ? when i turn on the key i dont hear anything, but if it was not working, i would think she would not run at all?? point also worth noting, it has dual tanks, but guy said switch/solenoid does not work. been using rear tank for years
The pumps have several power feeds. When cranking the 12 volts is from the starter solenoid. When running the power comes from the alternator. Key on and not running, pumps no run. There is also a inertia switch that shuts them off in and accident. It's down on the right side of the trans tunnel at the firewall in the cab.
