Fuel Heater?
Old Mar 28, 2008 | 04:15 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Fuel Heater?
Is the heater that thin wire thingamajig inside of the fuel filter housing with what kind of looks like a lead seal? I was just changing filters and noticed it for the first time ever. This is an extremely stupid question coming from a man that has had his truck as long as I have mine.........LOL
Old Mar 28, 2008 | 04:21 PM
bdrummonds's Avatar
bdrummonds
Yep Mark, thats it. tread lightly, those solders are not that strong.
Old Mar 28, 2008 | 04:34 PM
Markadeck's Avatar
Markadeck
OH Oh! I hope it is not supposed to be a complete ciruit and one end is connected and the other loose. If not, I hope I never have need of a fuel heater again.
Old Mar 28, 2008 | 05:44 PM
Markadeck's Avatar
Markadeck
I suspect I have broken it, I was fishing around for any o-rings that may have been in the bottom and found this little wire that I had never felt before so I just lifted up on it. One end is loose now and the other is connected somewhere. How important is this damn thing, and not having it working, is it gonna affect my mpg?
Old Mar 28, 2008 | 06:15 PM
bdrummonds's Avatar
bdrummonds
unplug fuel bowl heater plug, before you try to start truck, or you will blow the fuse.
Old Mar 28, 2008 | 06:18 PM
Markadeck's Avatar
Markadeck
Too late for that, but the fuse didn't blow. I had to start it after the filter change to check for leaks and it started right up and ran for five minutes until I shut it down. Anyway, is it not working going to do anything to my mpg?
Old Mar 28, 2008 | 06:34 PM
piotrsko's Avatar
piotrsko
my $.02:
If it isn't getting below 32 degrees F, then it isn't going to gell the fuel or make wax, which is why the heater is there in the first place. #1, a mix or lots of white DK does the same thing.
Pull the fuse and remember to fix it next time you do the filter. I myself would fix it on the thought procss that Ford put it there because of some reason.
Yes it will decrease mileage, because theoretically cold fuel is more dense. denser fuel has to take up less space. Will you notice the decrease? probably not
Old Mar 28, 2008 | 08:03 PM
Markadeck's Avatar
Markadeck
Well ****! This is real bad news. Does the entire housing have to come off to repair it? What do those of us that do the delete of the filter housing use for a fuel heater. I don't think taking this thing out anytime soon is on my priority list. I have to get the 35 mpg beater overgrown golf cart on the the road very soon or I'm going to be walking anyway.
Old Mar 28, 2008 | 09:26 PM
piotrsko's Avatar
piotrsko
I'm sorry, perhaps you misunderstood me.
the fuel heater isn't all that important, unless it is -10 winter in NODAK and snowing. Most of the filter delete people live with the slight possibility that their fuel MIGHT someday jell on a really really really cold day. Like I said earlier, white bottle of DK or DK 911 should be all that you need to ungell. Now if you live in florida, then you absolutely don't have a need for a heater.
No it isn't gonna affect your mileage. I was pulling your leg with theoretical rocket science.
however you gotta pull the housing on my '00 per the book unless you can get access to the thermostat screws on the bottom front to pull the thermostat. then it is just 2 screws in the bowl to pull out the heater. By the descriptions, you may not have to even pull the filter housing if you can get access to the thermostat connector in the bottom of the filter.
Old Mar 28, 2008 | 09:46 PM
jtharvey's Avatar
jtharvey
Not a darn thing. Two years in a row now and not a single issue. The last two winters here have been colder than usual as well. If you're in NC, the winters there shouldn't be as cold as I'm used to seeing here in MO, so no fears. I just keep my fuel treated, with a winter treatment during the cold months.
Old Mar 29, 2008 | 06:22 AM
Markadeck's Avatar
Markadeck
That makes life a little better. I know with a diesel that the warmer the cylinder the better but did not know the temp. of the fuel was all that important, I know in racing we always wanted our fuel as dense as possible.
Old Mar 29, 2008 | 06:30 AM
ron's power stroke's Avatar
ron's power stroke
i believe all the heater does is help disperse water..
Old Mar 29, 2008 | 07:14 AM
bdrummonds's Avatar
bdrummonds
Here you go Mark, pics and everything. https://www.ford-trucks.com/forums/6...placement.html
Old Mar 29, 2008 | 07:19 AM
Markadeck's Avatar
Markadeck
Thank you, could not get much simpler than that. Too bad I had not seen that thread earlier and then I would not have been wondering what in the hell that little piece of bailing wire (lol) was doing in the bottom of my filter bowl.
Old Mar 29, 2008 | 07:23 AM
bdrummonds's Avatar
bdrummonds
Sorry, I didnt have time to look that post up yesterday, and I just dont like to tell folks to search.
