351 Windsor or 302?
Old Oct 25, 2002 | 08:58 PM
Themainjam's Avatar
Themainjam
351 Windsor or 302?
i bought a 81' ford f-150. i have a 351-w performer intake with a edelbrock 4 barrelcarb. my friend says i have a 302... it has a 302 firing order. but i thought it was a 351 how can i tell the difference and why would it have a 302 firing order if it was a 351. it has 6 bolt valve covers. and did have a engine swap. truck orginally 302 according to the vin. but has a van dipstick. weird let me know how to tell the difference.
Old Oct 25, 2002 | 09:36 PM
lvmoose007's Avatar
lvmoose007
351 Windsor or 302?
quick way from the from front.....look at the front intake lip where it meets the block.....Is this right next to the distributor mount(the round flat area where it goes into the block), or about an inch above it? if the intake is level with the dist. base, it is a 302. If it is an inch or so above it, it is a 351.
Old Oct 26, 2002 | 03:01 PM
Themainjam's Avatar
Themainjam
351 Windsor or 302?
great its a 351 but why does it have a 302 firing order on the distributor? BTW thank you very much for the help.
Old Oct 26, 2002 | 08:59 PM
HotWhlz85's Avatar
HotWhlz85
351 Windsor or 302?
The cam determines the firing order. 302 and 351W cams can be interchangible.
Ron
Old Oct 27, 2002 | 06:35 PM
oft's Avatar
oft
351 Windsor or 302?
Another way to tell, 302 intake is 9 inches wide, 351, 11 inches wide.
Jayson
78 F100
Old Oct 27, 2002 | 06:50 PM
oft's Avatar
oft
351 Windsor or 302?
