head swap
Old Mar 28, 2008 | 07:46 AM
z1121jack's Avatar
z1121jack
head swap
I know you can put a 351 head on a 302 but can a 302 head with, smaller bolts installed on a 351? If so how do you get a small bolt to tighten in a large hole?
Old Mar 28, 2008 | 08:03 AM
Conanski's Avatar
Conanski
The solution is obvious.. you'll kick yourself for not seeing it when I tell you. All you have to do is drill out the bolt holes to 1/2", I have personally done this with a common drill press.. works marvy.
Old Mar 28, 2008 | 09:30 AM
z1121jack's Avatar
z1121jack
thanks it was obvious
