timing a 95 302?
Old Nov 3, 2002 | 09:23 PM
95 BRONCO XLT's Avatar
95 BRONCO XLT
timing a 95 302?
how do i check/adjust the timing in a 95 302 with mass air and all that junk?
ive got a 5.0 mustang and i cant find the the little spout connector that the mustang has and there is no module on the side of the distributor like the mustang so.... how do i check and adjust it?
thanks-
John
Old Nov 3, 2002 | 09:56 PM
groundrat's Avatar
groundrat
timing a 95 302?
The spout connector should be on the drivers side where the fender meets the firewall. It should be near the EEC test connector. Once you pull that just check it with the timing light. And make sure to put the plug back in. The truck wont like to run with out it.
Bill
Old Nov 3, 2002 | 10:56 PM
95 BRONCO XLT
timing a 95 302?
thanks for the info.
Old Nov 3, 2002 | 11:14 PM
95 BRONCO XLT
timing a 95 302?
what is the base timing on a 95 302(bronco)? 10deg. BTDC?
Old Nov 4, 2002 | 05:51 PM
MustangGT221's Avatar
MustangGT221
timing a 95 302?
