Sponsored by: Real Truck
Totally stumped need help!!
Old Mar 27, 2008 | 05:56 PM
davidson915's Avatar
davidson915
I was working on my trailer lights so I had my blinkers on for probably 20 minutes straight. The next day blinkers on my pickup did not work. This is a early 99 F350 7.3L. First I checked the fuses. All ok. Changed the flasher out. No luck. Bought a turn signal switch and installed it, no luck. Changed out the #23 fuse and #1 relay for the electronic flasher, still nothing. I have power at the flasher on the white wire with blue stripe. Power also on the turn signal, blue wire with an orange stripe. The #1 relay clicks when I install it. Is this normal? I don't know where to go from here. Is there somewhere online to get wiring diaghrams?
Old Mar 27, 2008 | 07:21 PM
BareBones's Avatar
BareBones
Are the lights on, but they don't blink, or off, and they don't blink...
high ho silver's Avatar
high ho silver
Did you check the fuses under the hood?
Old Mar 27, 2008 | 07:43 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
what is your email address? pm me it!
Ed
Old Mar 27, 2008 | 09:13 PM
davidson915
Lights are off, checked the fuses under the hood also. The fuses under the hood are just designated to the trailer right. That's the ones I checked.
