Plug on power steering circuit
What does it do?? Is it some kind of sensor for steering pressure? Is it a valve to cut back on steering boost at highway speeds? I was not aware the model had either. My vehicle doesn't even have a Check Engine light so I don't even know where such a sensor would go to.
What kind of noise?
John
https://www.ford-trucks.com/forums/7...ird-noise.html
I still can't figure it out. It's hard to describe, it comes and goes, and I can't pin down what it sounds like. I kinda wanted to interpret it as a bearing squeal, but it's also kind of a bit like a flapping/rushing sound. I can't readily picture in my mind exactly what it sounds like so I can't redescribe what I can't remember. Frustrating. It's sort of variable by itself and gave some unclear responses when I pulled tricks of putting it in neutral, giving it some gas in neutral, etc.
I did note that the coolant had been topped before leaving for that trip, and the sound appeared on the way back, and it seemed lower than I left it when I checked later. So I had an escaping cooling hitting the fan or belt as a theory. But it doesn't seem like it now.
It's not the wheel bearing because putting it in neutral makes it go away. Pretty sure the sound's from the left side, which suggests cracked exhaust manifold, AC compressor, power steering pump, or something inside the engine I don't understand. Maybe water pump is possible too. Noise didn't change when I turned the AC on and off. Didn't seem to change when I steered either but I was limited in how much I could do on the highway here.
There is also a rubber splash flap under the radiator and also aone between the radiator and engine on the passenger side as I recall, are they loose?
A mechanics stethoscope would work great in this situation. Harbor Freight or your auto parts store. I use on to pin point exhaust leaks and also vacuum leaks. I once found a major vacuum leak on my '98 van that a reputable shop couldn't find with a $3000+
smoke machine that was supposed to do the trick.......
John
That flap under the engine came apart long ago and has been long gone! Got in the way of oil changes, maintenance and such way too often and it was coming apart anyways. But no, it's kinda got a squealing component to it anyways.
The noise has so far been too fleeting to reproduce for long or while parked. I'm just driving down the highway and start to hear this subtle "hey, WTF is that?" noise for a few minutes. It's pretty disturbing just because I know it's not normal, I mean even if it's just the power steering pump thinking about giving up this is a huge towing bill and if I'm outta town with the parts store closed it's more. So I need to find out just what it is.
I guess that's power steering pump #3 for me then... crap, like 2 years between pump replacement here.
