1978 - 1996 Big Bronco
noise and code!!!
Old Mar 27, 2008 | 08:18 AM
nelly781's Avatar
nelly781
noise and code!!!
88 bronco with the v8 (5.0L) and my question about a code that is spitting out and a noise. i think they might be related though. the code syas that the catlyst efficiency low-bank2. the oxygen sensors monitor the catalytic converters ability to store oxygen. one cause is the cat is bad which could be caused by engine missfire or large vaccum leak, or oil leadking into the exhaust valve guide seals, piston rings. all of this infromation is from autozone spitting codes and information at me.
the noise happens the most around 25-35 mph, and over rough surfaces, which i thought something may be in the suspension, but when i'm parked i push up and down on it, and it doesnt make any noise. so im thinkin somethin could be lose in the cat. any thoughts?
(p.s. i would like to stay legal, i.e. no cutting off the cat)
right now im driving to check the gas mileage to see if that has changed any so thats my thoughts as of now.
Old Mar 28, 2008 | 04:34 PM
chrono4's Avatar
chrono4
First off, check the heat shield on the cat. They tend to rust at the spot welds that hold them on and rattle.
Old Mar 30, 2008 | 10:02 PM
nelly781's Avatar
nelly781
ill double check the heat shield, but i did get up under it and hit on the cat and i didnt hear anything rattle, which is kinda weird, and i revd the motor in idle and nothing rattled. so any other ideas?
wikdwest
Jul 19, 2014 12:12 AM
Buck268
May 26, 2013 10:38 PM
Duckman77
May 13, 2013 08:37 PM
yuskoholic
1997 - 2003 F150
Dec 10, 2011 10:53 AM
Jitters
1997 - 2003 F150
Aug 9, 2006 09:23 AM
