In my search of weird sound in the front of my truck! I did remove the auto lock and check if evrything seems right. Is that normal that the axle shaft have a big play. Like you grab it and you move it up and down, side by side and the play is at least an inch ??
The noise i am searching for is a grinding sound that is worst on acceleration and deceleration and also when hitting bumps! and also clunk sound. when i am going slow (in a parking) and turn I can hear the clunk and also feel it on the floor of the truck!
Could it be the needle bearing of the axle shaft that are bad ?
What is done so far trying to fix the problem!
-New Front Stabilizer/Link Bushing.
-New Front leaf spring Bushing.
-Did remove and clean/grease both Auto Lock!
