It's COLD Inside !
Old Mar 26, 2008 | 07:15 PM
dongc1's Avatar
dongc1
It's COLD Inside !
I am a happy camper today. Got my AC charged up and everything works well. It was 82' here today, so I decided it was time to find out if the AC was going to work. My wiring to turn the fan on when the AC comes on worked as planned. It blows real cold and seems to do a good job of cooling the cab down quickly. I hope to get my newly upholsted ranger seat and my carpet in on Monday. The carpet and insulation will help the AC and quiet thingds down a little more. If all goes well, I will be ready to do some cruise'n.
Old Mar 26, 2008 | 07:24 PM
eman92082's Avatar
eman92082
My A/C Sucks. Everytime I move that lever under the Dash my Cab fills with Dust and it ain't very cold.......
Seriously - Glad it worked out for you. Nuthin like some creature comforts.
Old Mar 26, 2008 | 08:36 PM
Kazoo's Avatar
Kazoo
82?? Was 32 this morning when I went to work, won't need AC till July
Old Mar 26, 2008 | 09:03 PM
divermo's Avatar
divermo
Texan
Very nice. What type AC did you use? What is you opion on your choice of wiring harness, was it easy to use on your '49?
Old Mar 26, 2008 | 10:31 PM
dongc1's Avatar
dongc1
I used Hot Rod Air for the AC.
I used a EZ Wire harness. It worked out OK. All of them take some thinking and planning if you're going to try and hide most of the wiring. The electric fan will run constantly unless you install a relay that is controlled by a thermostat switch. I installed a second relay that turns the fan on whenever the AC compessor turns on. Other than that, everything was straight forward and all of the wires were long enough.
Let me know if I can help you out.
Old Mar 26, 2008 | 10:52 PM
cmoritz's Avatar
cmoritz
Great News! Glad your A/c worked out,and glad it's warm enough to tell. That means the warmer weather is on it;s way.You've done a Great job on your truck!What kind of thermostat swx did you use? How did you wire it?
Old Mar 27, 2008 | 06:46 AM
tacson's Avatar
tacson
Do you use the 3 vent or 4 vent HRAir unit? What did you use for insulation? Do you have any install pictures you are going to post? Thanks I appreciate it
Old Mar 27, 2008 | 08:38 AM
48fordcoe's Avatar
48fordcoe
I have air but use my cowl vent most of the time
Old Mar 27, 2008 | 10:05 AM
Oz52F1's Avatar
Oz52F1
[QUOTE=eman92082]My A/C Sucks.
You might have wired it backwards.....it should BLOW!
Old Mar 27, 2008 | 03:15 PM
Dustin1690's Avatar
Dustin1690
Good to hear you got the A/C going its almost unbearable without in the hot summer
Old Mar 27, 2008 | 03:54 PM
cmoritz's Avatar
cmoritz
Oz52f1..That's a good one! LoL.....
Old Mar 27, 2008 | 09:44 PM
dongc1's Avatar
dongc1
I used a thermostat that closes @ 200' and opens @ 185'. I put it in the intake manifold close to the thermostat housing.
Here is a wiring drawing. the relays are standard horn relays. The top one turns the fan on when the temp gets to 200'. The bottom one turns the fan on whenever the AC compresser kicks in. That makes sure you have air flow through the radiator when sitting in traffic.
Hope this helps.
