Body lifts, the why not and the how to
#65
You know, on certain vehicles this is the preffered way to gain 3" of body lift, welding a piece of 3x3 square tubre to the body mounts. Not going to do it on my Ford, but it worked great on my Geo Tracker.
#68
"Seriously though, the people that insist on doing these type of things aren't going to take the time to read this"
In my case I'm glad I read it. I was considering doing a body lift on my 99 Expedition and after reading the write up I realize that it would be a bad idea. I think I ought to save and just go for a suspension lift.
My main reason for the lift was to safely go through water. Do you guys know where I can get a snorkel for the expedition? I'll try that until I can afford a 6" suspension lift.
#69
If your in deep enough water that you need to worry about a snorkel you have a lot more to worry about first... Like waterproofing all your electronics... You will get water in your floorboards before you engine sucks water (if your going slow) blasting through standing water is a great way to do all kinds of damage. Never a good idea. ever.
Computers on these vehicles do not take kindly to being submerged in water. So I recommend against running that deep.
How much water are you thinking you want to run through?
and finally to answer your question. I can't recall ever seeing an expedition with a snorkel, doesn't mean they don't exist though.
#70
#71
As a brother to the guys that will have to come rescue your sorry *** for trying to forge fast running flood waters, please don't. It is very easy to underestimate both the depth and the speed of water flowing across a street. Misjudge it and if you're lucky you have to get rescued, if you're unlucky your family has to decide between burial or cremation.
#72
#73
Received 3,148 Likes
on
and in that picture, you can see what everyone is talking about with body lifts. the extended bolts can not handle the stress, and snap. the bushing is still there on the frame bracket, as is the cab mount still attached to the cab. but the extended bolt failed, causing the head to snap off.
#74
08 escape help
I have a 08 escape 4wd and I want to give it a more off road look, and put on larger tires .. should I go with a lift kit? and if so were can I find one ?
or should I jus go with a levelling kit . not only am I going for the look but the dirt road to my cottage is a rough one with many large potholes
#75
