1978 - 1996 Big Bronco
Ignition module
Old Mar 25, 2008 | 10:57 PM
datzsun's Avatar
datzsun
Ignition module
How do I replace the ignition module on my Big Bronco, 5.8? Is there a special tool to remove it or do I need to turn the distributor? If so, how do I do that without messing up the timing?
Thank you.
Old Mar 26, 2008 | 09:29 PM
Aciancio's Avatar
Aciancio
what year? carb or EFI?
Old Mar 26, 2008 | 09:32 PM
Aciancio's Avatar
Aciancio
oh ya, if you need to move the distributor make a mark on it and the block using a fine point sharpie, then just line them back up.
Old Mar 26, 2008 | 09:44 PM
b4hntn's Avatar
b4hntn
I THINK I remember the distributor mounted ignition module has torx screws. I know the remote (fender mount) is a thin wall deep socket.
Old Mar 26, 2008 | 10:52 PM
datzsun's Avatar
datzsun
Hi,
It's a 1991 EFI. Looks like three screws, one is accessible, the other two are not. Looks like you might have to turn the distributor in order to access.
Old Mar 27, 2008 | 04:51 AM
b4hntn's Avatar
b4hntn
Have you pulled the the KOEO and continuous memory codes to see if the module is the issue?
Old Mar 27, 2008 | 01:51 PM
datzsun's Avatar
datzsun
No, I will do that and get back with the code I receive.
