Headers
Old Mar 25, 2008 | 10:39 AM
RedLesPaul's Avatar
RedLesPaul
Headers
I have a 79 F150 4x4 that has a 302 (not sure if it came with 302). I've been looking for a set of headers for it, but can't find them for 79 4x4 w/302.
Flowtech has a set, but year start at '80. I spoke to their Tech Services this AM, and they don't list any for 79. Are the frames that different from 79 to 80?
I'm wondering if I could make a set of these work?
Check em out at http://holley.com/12502FLT.asp
Thanks
Old Mar 25, 2008 | 11:10 AM
ibleedblue1385's Avatar
ibleedblue1385
You could probably get them to work. Im not exactly sure why they wouldnt? A set of shorties would also work if you cant find any long tubes.
Old Mar 25, 2008 | 11:26 AM
7375highboy's Avatar
7375highboy
I tried a set of 80 up headers and they will not fit. the pass side header is the one that dont fit.
Old Mar 25, 2008 | 11:57 AM
RedLesPaul's Avatar
RedLesPaul
HighBoy,
Did you ever find any that would fit?
Old Mar 25, 2008 | 01:05 PM
7375highboy
no there are no headers that fit that body with a small block ford. the problem is that the headers for those trucks have all the tubes real tight together,like for the 351m or the 390 trucks. the headers for the 80 up smallblock trucks,the tubes are in a row together and will not go past the starter. I never found anything that would fit ,but maybe try some late model shorties.
Old Mar 25, 2008 | 07:04 PM
73f100shortbed's Avatar
73f100shortbed
I tried to PM you but said I couldn't. I have some shorty headers off a Lincoln Mark VII. Maybe they will fit for you.
Old Mar 26, 2008 | 08:17 AM
RedLesPaul's Avatar
RedLesPaul
Thanks. I'm thinking about going the shorty route, but I'm new to this. To get pipes up to the shorties, does it become a trial and error thing? Or is there some "guide" to what pipes to use?
Old Mar 26, 2008 | 08:57 AM
7375highboy
get the headers to fit first,then have someone bend you a custom exhaust or just the down pipes.
