diff choices
Old Mar 24, 2008 | 09:39 PM
387designs's Avatar
387designs
diff choices
I Got a 9" with ls and 4:10 gears as part of a trade. My 85 300 with a few bolts ons, 4spd and 31*10.50s has an open 8.8 with 3.06:1 ratio. Should I swap in the 9 and swap 4.10s into the front?
Thanks,
Sean
Old Mar 24, 2008 | 09:44 PM
uncle.stosh's Avatar
uncle.stosh
4.10's are going to be a little steep for the 300 and 31's.
You'd be better off with 3.54's with that combo IMO.
Old Mar 25, 2008 | 07:19 AM
387designs's Avatar
387designs
So should I sell the 3rd member and buy a complete 3rd members with a more desireable ratio?
Old Mar 25, 2008 | 09:28 AM
Franklin2's Avatar
Franklin2
It all depends on what you are going to do with the truck. If you are going into mud up to the doors, then you possibly could use the 4.10's. If you do mainly street driving, it will be a dog, but you could keep what you have now. Around a 3.50 would be a good overall ratio with those tires though. And 3.50 is a common ratio. You will be looking for a 3.50 for the 9 inch, and 3.55 for the Dana 44 up front.
Old Mar 25, 2008 | 09:47 AM
Sycostang67's Avatar
Sycostang67
If you went with the 4:10's I would at least step up to a 33" tire to offset the difference.
Old Mar 25, 2008 | 09:51 AM
ibleedblue1385's Avatar
ibleedblue1385
I would go with the 4:10's because you never know down the road you may add larger tires.
Old Mar 25, 2008 | 10:57 AM
387designs's Avatar
387designs
I do plan on putting 33' on it but I have brand new MT on it now. It is not a daily driver, but it won't be a mudder either.
Old Mar 25, 2008 | 11:03 AM
82f3504x4's Avatar
82f3504x4
throw some 35s on there
Old Mar 25, 2008 | 11:06 AM
ibleedblue1385
Definitly go with the 4:10's. You wont regret it.
Old Mar 25, 2008 | 11:14 AM
387designs's Avatar
387designs
How should I approach the front diff? just buy new gears or could I leave them 3.06 for a little while till I have more money? I wont be using 4wd unless I get stuck anyway.
Old Mar 25, 2008 | 11:17 AM
ibleedblue1385
As long as you dont use the four wheel drive you will be alright until you get the money to do the front.
Old Mar 25, 2008 | 11:20 AM
387designs's Avatar
387designs
Ok, what about if I get stuck and tires are spinning, with the fronts spinning less will it be bad? or am I screwed?
Old Mar 25, 2008 | 11:35 AM
ibleedblue1385
Well AS LONG as the tires are spinning it wont do any damage, but the second they catch something, it could be bad news.
Old Mar 25, 2008 | 02:20 PM
Franklin2's Avatar
Franklin2
Actually the fronts will be spinning faster. It will put a lot of strain on the transfer case and driveline, even in the mud. 4.10 is a really big difference compared to ones you have now.
Old Mar 26, 2008 | 09:23 AM
Sycostang67
I'd pull the front DS so aren't even tempted to try.
