Squeal the tires?
Old Mar 24, 2008 | 06:58 PM
bbauman's Avatar
bbauman
Squeal the tires?
Got a new to me '00 Excursion, V10 4x4 with 4.30 LS gears off Ebay. Had never driven an X. Shouldn't it be able to at least get a little squeal of the tires when you tromp on the gas? That much HP, torque and low gears.
It does the same thing my '01 Supercrew 5.4, 4x4, 3.55 LS and 17" tires does, bogs down and then slowly takes off.
Does the computer do this instead of letting them surge forward or spin the tires?
Old Mar 24, 2008 | 07:17 PM
1buzzbait's Avatar
1buzzbait
i would rev the engine up in neutral,than slam it into drive!!
Old Mar 24, 2008 | 07:35 PM
X-70STANG-F150's Avatar
X-70STANG-F150
hold the brake, push the gas, slowly let off the brake
Old Mar 24, 2008 | 10:25 PM
bbauman's Avatar
bbauman
guess i haven't tried a brake stand.
suppose the question is pretty stupid anyway. maybe i should have phrased it as 'are Ford's computer controlled to be dogs off the line?'
Test drove Tahoe, Suburban, and Durango. They all at least chirp the tires. Expedition, Excursion and F150 don't. Just seems odd.
Old Mar 24, 2008 | 10:51 PM
bgalaxy67's Avatar
bgalaxy67
My 00 with 3:73's still gets a chirp even after 130k
Old Mar 24, 2008 | 11:05 PM
VaSheriff's Avatar
VaSheriff
Why would you want to?
Old Mar 25, 2008 | 01:11 AM
Monsta's Avatar
Monsta
Sit. Stay.
I think a lot of IS Ford PCM programming. I can't really say for 100% certainty, but I've experienced the same thing with my 04 F-150, 03 Expy and my 05 Excursion. You gotta do a brake stand to break the tires loose.
Old Mar 25, 2008 | 01:27 AM
i eat hybrids's Avatar
i eat hybrids
Can u guys break the tires loose? I kno i cant with the 33's. I kno i can on wet pavement! But then of course ive never tried to brake it loose with the old stock 31's on dry pavement.
Old Mar 25, 2008 | 02:02 AM
AK-Excursion's Avatar
AK-Excursion
Ive done it before, with the break stand. Made like an 8 foot burnout, but I got a 6.0L PSD I think it has more torqe.
Old Mar 25, 2008 | 06:34 AM
djhuff's Avatar
djhuff
I got a decent chirp (more like a short spin) one evening from a dead stop with just a stomp on the pedal. Some guy stopped in front of me at an intersection and I almost missed the light. Really didn't expect it, but it was nice.
BTW, V10 with 3.73 non LS.
Old Mar 25, 2008 | 07:24 AM
X-70STANG-F150
Smile
not trying to break any speed records, but hey, inquiring minds want to know!
might want to try to impress one of those power smoke diesels some day.
Old Mar 25, 2008 | 07:42 AM
bbauman's Avatar
bbauman
Not saying flooring it is something that would be done often, if at all, but when the math says a vehicle should be able to bark the tires and it can't I like to know why.
Old Mar 25, 2008 | 08:32 AM
whjco's Avatar
whjco
I've got the opposite problem. I have to be real careful, particularly on wet roads, to use a light foot. Mine likes to break traction on the white stop bar on the pavement when accelerating from stop lights and the rear end can break loose fairly easily with moderate acceleration in turns. I replaced the BF Goodrich Wrangler A/T's with Michelin M/S which has made it much better, but I still have to be gentle with it. It can also spin the tires without any problem on dry pavement from a dead stop, although I don't do it deliberately. I've got 3:73 gears and a 7.3 PSD that's programmed to level 2 with a Hypertech programmer.
I have to agree with VA Sheriff, "why would you want to?". If it gets you down the road safely with plenty of passing and towing power then I'm a happy camper. That's a lot of unnecessary torque on the driveline when you try to spin the tires on a 4 ton vehicle.
That V10 is a hoss of an engine and will serve you well.
Old Mar 25, 2008 | 08:39 AM
VaSheriff's Avatar
VaSheriff
Correct. Especially since the transmission is a weak spot in the first place.
Old Mar 25, 2008 | 10:12 AM
i eat hybrids
I can do a burn out like that, but my trans realllly hates me
