ARP Studs Worth It?
Old Mar 24, 2008 | 03:41 PM
Vrybusy's Avatar
Vrybusy
ARP Studs Worth It?
Having the head gaskets done in a couple of weeks. Just wondering if the ARP Studs are worth installing? At $500 I was wondering what everyone thinks. The Tech said that he would install them if I purchased them. Thanks!!
Old Mar 24, 2008 | 03:51 PM
rollerstud98's Avatar
rollerstud98
If you can afford it do it, as long as the heads are checked to make sure they are true and flat, then with the head studs installed you have one less thing to worry about with these 6.0's
Old Mar 24, 2008 | 03:57 PM
mnmwhit's Avatar
mnmwhit
Yea they are worth it.
They are critical if you plan to do performance MODs to your truck.
Old Mar 24, 2008 | 04:02 PM
rollerstud98
even without performance mods i think they are critical, mind you i'm at 200k km's with not head gasket problems but its always on the back of my mind and one of the things i want to do to my truck this summer
UGA33's Avatar
UGA33
if the tech is going to do it under warrenty and all you have to do is supply them then definately yes
Old Mar 24, 2008 | 04:25 PM
OZX1's Avatar
OZX1
If it were me, I would do it in a hot-second.
Old Mar 24, 2008 | 05:07 PM
tex25025's Avatar
tex25025
I would definately do them, but also(as rollerstud98 already stated) make sure that they look over your heads and either machine them or totally replace them and make sure the new ones are good to go otherwise you'll have head problems despite the studs(you would have problem rather or not they do studs if they don't check the heads for flatness). The good news with studs if you do have problems again with heads(if they don't do a good install job), you can reuse them unlike the bolts.
Old Mar 24, 2008 | 06:02 PM
Kep4's Avatar
Kep4
Jäger
Absolutely have them installed. As stated above, make sure you ask the Tech about checking the block deck and the heads to ensure they are perfectly flat.
Keep in mind: You MUST take your truck to the same service department for any work involving removing the heads. Example: tracking down and repairing the source of an oil leak. Another service department may not be 'stud-friendly' and could (wrongly) blame problems on the studs since they're not Ford parts.
I had the studs installed and am much more confident in my truck, especially when towing.
Old Mar 24, 2008 | 07:02 PM
Vrybusy's Avatar
Vrybusy
Thanks! Looks like I'll be buying a set of studs! I currently run a Bully Dog with an Air Raid intake and MBRP exhaust - Turbo Back (no cat). Sounds like the studs are a good investment.
Old Mar 25, 2008 | 12:38 AM
GregsSD's Avatar
GregsSD
Yes!!! Do it!!!
I had mine done last summer after the egr cooler and headgaskets went south.
You will have a much more reliable truck with the studs in!!!
Old Mar 26, 2008 | 09:13 PM
buckweet1980's Avatar
buckweet1980
How common is it for the heads to be warped?
I need to do the gaskets on mine.. I also infer that its best to get them decked as well..
Thoughts?
Old Mar 27, 2008 | 12:20 AM
adambomb's Avatar
adambomb
i don't know how common it is but it does happen. i bought my truck used and stock and 2 thousand miles after that the head gaskets blew and both heads had small cracks.
Old Mar 27, 2008 | 10:27 AM
OZX1's Avatar
OZX1
Originally Posted by GregsSD
Yes!!! Do it!!!
Hey, GregsSD-
You were just having too much fun in that shot! What sand were you in? Maybe Pismo?
Keep it up(right)!
Brian
Old Mar 27, 2008 | 10:59 AM
GregsSD's Avatar
GregsSD
Originally Posted by ozx3+1
Hey, GregsSD-
Keep it up(right)!
Brian
You got it !!!
I was playing with family and friends for easter week, I have just as much fun playing in the dunes with the truck as I do with the quads!
Old Mar 27, 2008 | 11:39 AM
OZX1's Avatar
OZX1
Me too, but WHERE were you playing?? Sand is sand, but I don't know where NorCal sand is at... Only SoCal sand.
