Alright guys, i give. I am having a problem when I put my truck in gear and try to move. It sputters until it starts to roll and moves up in RMP. I have pulled the carb off and cleaned it, and changed my fuel filter. It has the Duraspark ignition, and the module is brand new. Timing is between between 10-12 degrees BTDC, just from eyeballing it. It does seem to be running pretty rich just from the strong exhaust smell and the black soot at the header collectors
I checked the advance by putting suction on the valve, and watching it move in the distributor. Im not sure how much vacuum the engine is giving though. The linkage is correct, and both screwa are set 1 and 1/4 turns from fully closed i guess. I set them to specs in the haynes manual for the year model truck.
im sure how to adjust it as far as the engine running. So do you think that it is getting too much fuel at low RPMs, and mixture needs needs more air? If so, whats the best way to tune this
so would this affect trottle response from a dead start. I have a friend that is having the same problem with a brand new edlebrock 4 barrel with an electric feed.
There a few things that come into play
condition of the Distributor and ignition parts
vacuum leaks
linkage adjustments
condition of carburetor
quality of fuel
