6.9L diagnosis
So I have an 86 f250 4x2 blah blah, with the venerable 6.9L diesel in it. The engine smokes a little under load, and hardly has any hp/torque left in it. It even has died a few times while running, and has problems starting when its pointed up hill. I ran a compression test, and everything turned out fine. I think the problem is in the fuel delievery, as thats pretty much the only thing that can kill a diesel when it gets running. I only use the truck for dump runs, and I dont mind really tearing into it to find out whats going on.
Any suggestions on where to start?
I heard that to diagnose the fuel system up to the injector pump you can splice in a piece of clear tubing and check for air bubbles... sound like a good idea?
If this issue is discussed somehwere else, or you have any sort of insight, lemmie know.
Thanks a bunch, headed off to the store to get the injector rebuild kit, but more advice on the problem is more than welcome...
Many have stopped the air by shoving a bolt in the drain tube.
Any idea how many miles are on the engine?
Are the injection pump and injectors the originals?
The truck has 186K on it, I believe... Its a family thing, so its not like I bought it without knowing how many miles were on it, alltho it very well could be 286k...
The injector pump is stock, and the injectors were replaced "sometime in the past..."
The rebuild kit helped alot, there is definately a difference in power. There is still some smoke at startup and when its under stress.
Here are some interesting things that I found while inspecting and cleaning off the injectors:
2 of them had a metalic gunk buildup all the way from the threads to the copper washer, with a brown ooze all over.
1 of them came out completly covered in oil. That one concerns me the most.
Any ideas?
The oil probably came from there, after it was around the ouside of the injector it just stayed there and cooked.
Any chance the metallic looking stuff on the threads was Never Seize?
A small amount of smoke is rather normal.
The harder you are on the go pedal, the darker it will get.
