Problem with gear selector
Old Mar 23, 2008 | 10:19 PM
skarpenz's Avatar
skarpenz
In my '90 F150 302ci w/ AOD trans. My gear selector has been offset since I've owned the truck. To put it in OD I have to put the selector in the N position and reverse is b/w the P and R positions. Its screwy, and a bit annoying. I did a search but no one had any info really. Any idea how to fix this?
Old Mar 23, 2008 | 10:52 PM
gweeds's Avatar
gweeds
On the driver side of the transmission is where the shifter linkage goes into the trans. You can loosen the bolt there and fudge it whichever way it needs to go to make it select the correct gear.
