head casting #'s
Old Dec 12, 2002 | 11:10 AM
Brian460's Avatar
Brian460
head casting #'s
Where do I find the casting #'s on a 302 for the heads?
Old Dec 12, 2002 | 05:23 PM
pcmenten's Avatar
pcmenten
head casting #'s
They would be on the head gasket side of the cylinder head. Typically it's a four character sequence such as F7TE.
Old Dec 12, 2002 | 11:50 PM
Brian460's Avatar
Brian460
head casting #'s
So if you had a mirror would you be able to see them with the heads bolted to the motor in the car?
Old Dec 13, 2002 | 12:39 AM
pcmenten's Avatar
pcmenten
head casting #'s
Yes, if the intake manifold is off. What kind of engine are you looking at? 5.0, 302, 351?
Old Dec 13, 2002 | 08:59 AM
Brian460's Avatar
Brian460
head casting #'s
'83 302 H.O. in a Dominator Mustang
Old Dec 13, 2002 | 09:41 AM
pcmenten's Avatar
pcmenten
head casting #'s
I'll take a guess at what castings you have; D8AE. The casting numbers are on the underside of one of the intake ports. With the intake manifold off you should be able to put a small mirror under each of the intake ports and eventually see the number.
Old Dec 13, 2002 | 05:18 PM
mudder trucker's Avatar
mudder trucker
head casting #'s
