timing belt
Old Mar 23, 2008 | 06:48 PM
cpettymore7777's Avatar
cpettymore7777
timing belt
when should a timing belt be changed on a 95 351?
Old Mar 23, 2008 | 07:24 PM
jr32560's Avatar
jr32560
actually it uses a chain-and as far as I know there is no set interval -i have checked them by grabbing the lower pulley and check by turning the lower pulley left to right up and down depends on how you look at it-the amount of slack should not be that muck less than a 1/4 of and inch-you sometimes have to remove the belt to do this-1/4 each way should be okay
