Which pushrods to use???
Old Mar 23, 2008 | 02:52 PM
fordfan302's Avatar
fordfan302
Im doing a build for my truck and Its coming time to install the pushrods and I have 2 different set to use and dont know which ones...
I have an '86 Roller NON HO shortblock, with a factory '89 HO cam installed and E7 heads on top...Should I use the non roller truck pushrods which are longer or the pushrods that came with the '86 block which are shorter...OR if there a certain size that I need to buy
Old Mar 23, 2008 | 10:31 PM
Beanscoot's Avatar
Beanscoot
Is this factory '89 HO cam a roller or flat tappet?
If it is a roller, use the pushrods that came with the '86 roller block. If it is a flat tappet cam, use the other pushrods.
Old Mar 23, 2008 | 10:38 PM
Conanski's Avatar
Conanski
The '89 HO cam is a roller cam so you need the shorter pushrods.
Old Mar 23, 2008 | 11:42 PM
fordfan302's Avatar
fordfan302
Thanks for the help guys
Old Mar 24, 2008 | 05:35 AM
HemiEater's Avatar
HemiEater
you are using the rollor lifters right?
Old Mar 24, 2008 | 09:43 PM
fordfan302's Avatar
fordfan302
Yes I am, the only thing different is the HO cam and E7 heads
