92 explorer brake problem, NEED help
Old Mar 22, 2008 | 07:42 PM
ckcn10's Avatar
ckcn10
my 92 explorer is equiped with the rear abs, and i just completed a running gear swap from a 91 explorer that had lower gears. Now when i attempt to blead the brakes i have no pressure whatsoever to the rear, also the abs light is on, and flashes once when you start the vehicle. What do i do?
Old Mar 24, 2008 | 03:16 AM
ckcn10's Avatar
ckcn10
Update-
the REAR ABS light doesnt come on anymore, but still no pressure to the rear.
any suggestions?
Old Mar 24, 2008 | 10:04 AM
mrshorty's Avatar
mrshorty
Can I assume you are talking at the bleeder valve on the rear wheel cylinder? If that's the case, I would probably start by visually inspecting the brake lines to see if there are any obvious kinks or anything that would be preventing fluid flow. Then start by breaking connections until I located where the fluid flow was being stopped.
