Testing Idle Air Control Valve
Old Dec 11, 2002 | 09:01 AM
MustangGT221's Avatar
MustangGT221
I havn't yet, its on the to do list.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Dec 11, 2002 | 02:12 PM
brown 4x4's Avatar
brown 4x4
Have you guys checked your codes to be sure something else isn't causing the problem?
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old Dec 11, 2002 | 09:18 PM
gamehunter's Avatar
gamehunter
What do you mean it is a non cleanable IAC? What I have done in the past is just squirt some PB blaster (or any other solvent clearner/carb clearner) in the 2 wholes and let it set for 5 minutes and drain it out and wipe the residue out. This does get rid of the so called "protective anti-carbon coating" on the inside of the IAC (which maybe is what your talking about) but I havn't found that to be a big deal. If its dirty already from 8+ years of use, how you gonna make it dirtier by cleaning it? Hope you fix it. I have that same problem every once in a while on my truck. But It doesn't happen enough for me to care about fixing it.
OH!!! I like your analogy of COLD. lol Im used to temperatures around 0 during the daytime around here at this time year.
Old Dec 11, 2002 | 10:19 PM
mike_v2v98's Avatar
mike_v2v98
checked my codes running and not running
no codes just the self test pass
gonna try cleaning the egr tonight and mayeb make up a restrictor plate ive heared good things about these so its worth a try
Old Dec 12, 2002 | 01:23 PM
MustangGT221
There are two types of IACs used. My 95 Dealership Service Manual shows a cleanable and non-cleanable one. The non-cleanable ones you can spray carb cleaner in the air flow inlet/outlet but a complete cleaning is not possible. The cleanable one is only used on the 5.8L lightning and the 7.0L.
Old Dec 14, 2002 | 11:17 PM
mike_v2v98's Avatar
mike_v2v98
mustang i have solved my high idle problems
picked up a map sensor at the wreckers just to try it and sure enough after a few days of driving my problems gone
Old Dec 15, 2002 | 05:18 PM
MustangGT221
Congrats. Hope thats my problem, thanks for the imput.
Old Dec 19, 2002 | 06:19 PM
bud 321's Avatar
bud 321
I just unpluged mine and it runs great now. The rpms don't stay up like it use to when its cold, you've got to keep it reved up until it is warm.
Old Dec 26, 2002 | 09:26 PM
DWMAC's Avatar
DWMAC
I had a idle prob for a while too in my 93 5.8L. First thing I tried was the IAC, but that didn't solve it. Ended up being my TPS. It was way out of tolerence but didn't give me a "check engine" light. The TPS fixed the idle and greatly improved throttle response.
Old Dec 27, 2002 | 09:34 AM
Nathan's Avatar
Nathan
Old Nov 15, 2005 | 09:37 PM
Rofronzo's Avatar
Rofronzo
"Sticky Throttle"
Hey I have a 01 Mustang that has the same "sticky throttle problem" It's been haunting me for a while and I can't figure it out. Please help!!!
Whenever you go to shift the rpms stay put for a few seconds.
Old Nov 16, 2005 | 06:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Rofronzo, to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 16, 2005 | 12:06 PM
  #28
Dannym's Avatar
Dannym
Intake manifold leaks can make it idle high due to the extra air coming through the leaks that can't be stopped by the throttle valve. I had that problem.
Old Nov 17, 2005 | 10:52 AM
  #29
Rofronzo's Avatar
Rofronzo
The rpms still stay high but I disconnected the IAC valve and the rpms drop fast when I shift. So I don't know if its the IAC valve or my computer. Should I replace the 80 $ IAC Valve or pay 80 $'s to have my car checked out and then the price of the parts?
Old Jan 17, 2006 | 02:24 PM
  #30
natewill's Avatar
natewill
I too now have the high idle demon. Unplugged the IAC and the idle dropped. Sprayed some Throttle Body cleaner around vacuum lines and plenum gaskets and such, and had no change in idle. But is the moral of the story that a high idle could be an IAC, or a mysterious seal leak, or a TPS, or an EGR, or an EVP? Is this the path I have to take?
