engine problem
Old Mar 22, 2008 | 02:14 PM
learpilot's Avatar
learpilot
engine problem
Hope this is not too far off base as it concerns the engine in my 1963 Galaxie 500xl which I restored last year. It is a "rebuilt" 390, that is I bought it as a rebuilt engine but when I started it up it had a pronounced click in the engine which was determined to to be a couple of bent push rods on the left side. These were replaced and every thing else that seemed to be needed was done. The problem is that ever since (and it only been 200- 300 miles) it smokes badly ( blue smoke for the left side exhaust-it has split dual exaust) and the inside of that tailpipe is coated with oil. Any ideas on what the likely problem might be? Thansk in advance for any help.
Old Mar 22, 2008 | 02:19 PM
sparky's Avatar
sparky
My bet is valve seals or valve guides are worn on that cylinder bank.
Oh yeah could also be rings........ try a compression test wet and dry........
Old Mar 22, 2008 | 02:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If the valves on the left side hit the pistons at some point, it would ruin the guides and bend the pushrods. Could be related.
Old Mar 22, 2008 | 03:08 PM
cool 48's Avatar
cool 48
I was kind of thinking along the same lines there. If you had a couple of bent push rods on the left bank,and now the left bank is smoking, then I would bet the valves are bent. Jut my observation. Does it sputter a little on the left side ?
Old Apr 8, 2008 | 01:59 PM
learpilot's Avatar
learpilot
Just thought I would update you on this problem. Had the engine opened up and found that the engine had been stored after rebuilding and evidently had water in one of the pistons. That cylinder is pitted all the way down to the bottom and must be bored and resleeved. Of course the shop that did the work is out of business. Thanks for all your suggestions
Old Apr 8, 2008 | 02:48 PM
Sandidande's Avatar
Sandidande
Hi Learpilot,
We are always happy to help out a foreigner in the forum. I'm not sure you knew this, but there is a dedicated forum just for FE engines at FTE. There is a lot of knowledge there too. I bounce back and forth because I have a 390 in my 51 F1.
Good luck with the rebuild and come back anytime!
PS. I'll post an FE 390 Pic for you as encouragement!
[/IMG]
