Sponsored by: Auxito
Oil filter hoses?
Old Mar 22, 2008 | 08:06 AM
WALJON's Avatar
WALJON
Oil filter hoses?
Hi I posted this question in the expedition forum but didn't get an answer.
I was wondering if the f150 is the same as my expedition and has the oil filter behind the front bumper? and if so has anyone had to change these hoses and are they pricey.
Thanks
Old Mar 22, 2008 | 09:09 AM
Bobby82490's Avatar
Bobby82490
Yes alot of these trucks have them behind the bumper. Did you bust a line or something?
Old Mar 22, 2008 | 09:21 AM
WALJON's Avatar
WALJON
No I just noticed last service that the hoses were sweaty wet with oil so I think I want to change them. Are the hoses sold separate? or is this a unit?
thanks for the reply!
Old Mar 22, 2008 | 09:31 AM
Bobby82490's Avatar
Bobby82490
I dont know if the are sold separate. If you go to ford, they will charge you big time for them. I bet if you went somewhere that made hoses for equipment, they could make you a hose for a decent price.(Make sure you bring the hoses with you)
Old Mar 22, 2008 | 09:33 AM
Bobby82490's Avatar
Bobby82490
Oh yeah, if it was me i would clean the hoses off to see how much it leaks and where they leak.
Old Mar 22, 2008 | 09:39 AM
WALJON's Avatar
WALJON
Thanks yeah I did wipe them down good when I serviced it and looked again yesterday and they are a bit wet again I will wipe them down good again and watch it hop fully its just the oil filter seal or something.
Old Mar 22, 2008 | 10:01 AM
Ron W.'s Avatar
Ron W.
The 2 hoses are sold as an assembly and quite often depending on the application the catalog will ask if there is a threaded hole on the block side of the hose assembly for oil pressure switch. And yes they are expensive, but cost less than a new motor should one blow while your driving.
Old Mar 22, 2008 | 10:56 AM
galaxie641's Avatar
galaxie641
I've thought about replacing mine a few times but don't like what it will cost. If you have some made you still might have issues with the ends, I am guessing they are not a common size and thread. If you have it made take off the old hoses and have them matched for length and inside diameter. I'd also only go with high pressure hydraulic lines because they have plenty of strength and will not rub through or get punctured easily.
Old Mar 22, 2008 | 11:22 AM
khadma's Avatar
khadma
Carpenter Local 745
Go to an industrial hose company and have new hoses made up, they can custom make them for you with just about any fitting on the ends.
I usually go big time and use braided lines so I do not have to worry about them anymore, and they are still cheaper than OEM.
Old Mar 22, 2008 | 11:44 AM
Ron W.'s Avatar
Ron W.
Thumbs up
Guys these are not seperate hoses such as 2 hydraulic lines, there is a flange or manifold as Ford likes to call it on the ends. To see what I mean by manifold go look at the back of your A/C compressor where the hose assembly attaches, 2 hoses attached (part of) to the manifold attached to the compressor. You might be able to improvise but I don't see it costing any less or being any better.
WALJON, if you're going to replace them you might as well them do it right.
Old Mar 22, 2008 | 12:44 PM
WALJON's Avatar
WALJON
Thanks guys for the replies I kinda figured it was a whole assembly I will shop around for prices before I go to the dealership someone must make an aftermarket assembly.
thanks again
Old Mar 22, 2008 | 12:51 PM
coyote81's Avatar
coyote81
Does anyone know what size the 97 F150 comes with. At work we have stainless steel hoses with stainless steel braiding around them in all sizes and lengths. Anyway just wondering what size it is.
Old Mar 23, 2008 | 07:41 PM
dparr460's Avatar
dparr460
did u fix it
Old Mar 23, 2008 | 07:44 PM
WALJON's Avatar
WALJON
Originally Posted by dparr460
did u fix it
No not yet I have been busy with the kids and Easter
this week for sure
Old Mar 23, 2008 | 07:46 PM
dparr460's Avatar
dparr460
did u get some eggs
