351m problem driving me nuts
Old Aug 6, 2008 | 09:20 PM
  #31
fleetbob1's Avatar
fleetbob1
me 2 did you use the carb cleaner method ?
if you had the heads milled too much you will have a intake leak!!
Old Aug 7, 2008 | 12:24 AM
  #32
f-420's Avatar
f-420
your problem is most likely all in your carb.....has to do with the amount of fuel that you are dumping in a motor that cant get the air to match.....either change your jet size or install a high rise intake with a racing cam
Old Aug 11, 2008 | 07:24 AM
  #33
fatherdoug's Avatar
fatherdoug
Since the problem is solved - danlee, you mentioned a heat riser valve on the exhaust manifold. Is this valve installed at the outlet of the exhaust manifold? I don't seem to find one on my 400( 78 F-150 with stock engine), but headers have been installed. I remember the old style on a 59 ford with a visible coil spring on the exhaust manifold.
I was just wondering if this might help solve a long-term overheating problem?
Old Aug 11, 2008 | 07:37 AM
  #34
danlee's Avatar
danlee
It's been so long since I have seen a stock exhaust setup on a 400, I am not sure what is supposed to be there.
I think that the modern version of the heat riser valve is a vacuum cylinder that is operated by a temperate sensitive valve. The exhaust flow valve opens when the motor gets warm.
If you have eliminated this valve, then you should have no problem, but it may take a little longer for your motor to run efficiently in cold weather.
Removing this valve will not affect normal operation at full temperature.
Blocking the exhaust crossover in the intake manifold will keep the manifold cooler. This will help make more power, but at the cost of fuel mileage.
None of this should apply to the engine operating temperature.
Look at your Fan, Shroud, Tstat, Belt slippage or Radiator blockage for cooling problems.
Old Aug 11, 2008 | 08:01 AM
  #35
fatherdoug's Avatar
fatherdoug
Thanks for the reply, Dan. The list of items replaced in the cooling system with new is quite long. Basically everything has been replaced, including the engine(stock rebuild - Oh, TMI, where were you when this engine was rebuilt?) New radiator for a 460 engine, new robertshaw 180 deg thermostat, new heavy duty fan clutch, new water pump, new fan shroud(Dennis Carpenter), new radiator hoses, new fan belts, new EGR with a 135 deg F. cut in temp, timing set at 10 BTDC, etc.
By overheating, I mean about 220 deg F.
I know this subject has been beat to death, but after three years, I'm still fighting it.....
Old Aug 11, 2008 | 12:14 PM
  #36
Rebel Warrior's Avatar
Rebel Warrior
There are only a couple of causes for this problem. if there is gas dripping from the booster nozzles at idle, the float level is either too high or a stuck needle seat, or the float has become saturated with gas or leaked into it(brass only) and sunk. these are the most common. It could be that your idle mixture screws are adjusted wrong. If your carb is not dripping from the boosters at idle, your problem sound like its in the idle circuit. Also I just looked at both my 351M & 400 neither have a heat riser on the exhaust manifold. it is probably boiling the gas out if its getting that hot. i hear alot of talk about removing the valley pans also, it is designed to keep the hot oil off the bottom of the intake. since yours has so few of miles it should still have it.
Hope this info helps.
RW
Old Aug 11, 2008 | 12:39 PM
  #37
danlee's Avatar
danlee
When does it overheat? At idle/low speed or at highway speeds?
Low speed overheating and cool cruising indicates an air flow problem. Overheating at highway speeds indicates a water flow or load problem.
Maybe the head gaskets were installed wrong!
Old Aug 11, 2008 | 07:32 PM
  #38
fatherdoug's Avatar
fatherdoug
Low speed, idle is no problem. So, airflow is ok?
Overheating occurs under load - long hills, or pulling a 18' camp trailer. Outside temperature makes a big difference also. It just seems like it can't remove the heat fast enough. All the changes made above did help the overheating problem, but I just dread pulling the camp trailer 100 miles beacuse it involves constant stops to cool down the engine.
I actually had them pull the heads after the engine was installed, to verify the gaskets were installed correctly. They were.
I am leaving at midnight tonight, so I can pull the trailer up the hill while it is cool. Thanks for the suggestions.
Old Aug 11, 2008 | 08:22 PM
  #39
danlee's Avatar
danlee
Check your pulleys. Do you have the right pulleys? A crank pulley that's too small or a WP pulley that's too large will slow the water pump, resulting in reduced water flow. Did you use your old pulleys on that rebuilt motor or some pulleys that came with it?
Old Aug 11, 2008 | 10:52 PM
  #40
fozzy's Avatar
fozzy
I have owned the AFB carters and edelbrock for many years and tuned a lot of them too. They truly do not like 6psi as someone mentioned. 5.5 is the max I will put to these carbs.
Old Sep 14, 2008 | 01:22 AM
  #41
1979Broncof250's Avatar
1979Broncof250
Oil filter
The Low oil Pressure could be caused by one of two things, The Old filter. (Try a K&N filter fixed my problem with low oil pressure when the engine is hot) The other could be the cam bearing. You could have an Intake Leak, the Al intakes don't like the metal intake gasket. I use two sets of Fel-Pro 1240 with the metal gasket in-between, You might need to have the intake machined to do this. Try visiting http://www.fowlerautomotive.com/Intake_Manifold_Machining.html he sell some information the helped me a lot when I was having head to Intake problems. Also the heads tend to warp around the exhaust crossovers to the outsides of the head and this can cause internal exhaust and vacuum leaks. Try checking this with a strait edge. I hope this helps <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Sep 14, 2008 | 09:07 AM
  #42
ctubutis's Avatar
ctubutis
Huh??? If this were an issue, wouldn't I have heard or read about it from other sources,
too?
Old Dec 18, 2009 | 03:33 AM
  #43
mac10guy's Avatar
mac10guy
ANYTHING over a 600cfm carb in a 351m is TOO MUCH FUEL. you have to tune down your carb and that still might be too much fuel! you have somethin like a 750 edelbrock you say? how is it tuned because i think tuned down thats still too much fuel intake for the modified.
Old Dec 18, 2009 | 03:34 AM
  #44
mac10guy's Avatar
mac10guy
crap sorry to revive a dead thread dint even look at the date my bad! i couldnt find an answer to the oil pressure tho what IS the stock oil pressure for a 351m?
Old Dec 18, 2009 | 06:21 AM
  #45
fleetbob1's Avatar
fleetbob1
i think its about 18 on a hot engine
i just rebuilt mine with a high volume oil pump and i get 20 hot at about 800 rpms
