Tail, running, dash lights went out.
Old Mar 20, 2008 | 06:15 PM
Catsailor's Avatar
Catsailor
All of a sudden my dash lights, tail lights, and running lights behind cab stopped working. My right brake light, headlights and front turn signals work. Any got suggestions? I have checked the fuses below light switch.
Tom
Old Mar 20, 2008 | 08:45 PM
Franklin2's Avatar
Franklin2
Some of these trucks have a problem with the tan/white wire going to the headlight switch burning in two. Pull the headlight switch and see if you have power on the tan/white.
Dave Sponaugle's Avatar
Dave Sponaugle
Check the wiring.
There is a plug at the end of the frame, drivers side.
That is where I had most of my bed/tail light problems when mine had the factory bed on it.
Dash lights sound like a switch/dimmer problem.
Running lights and tail lights may also be a switch problem.
Old Mar 20, 2008 | 08:52 PM
Catsailor's Avatar
Catsailor
Thanks, I'll check those out tomorrow morning.
Old Mar 20, 2008 | 09:17 PM
Ironman03R's Avatar
Ironman03R
Very comon for the headlight switch to burn out and melt the conector. When I replaced mine I installed a relay so the switch doesnt have to handle so much current.
