Blown Hg
Old Mar 20, 2008 | 07:55 AM
benniebob's Avatar
benniebob
Blown Hg
My 03 Psd Has Been In The Shop The Last Two Weeks For Bhg, Is Ready To Be Picked Up. Don't Know Yet What All They Did I Won't Pickup Until Friday Afternoon, Did Replace Bolts With Studs Though.
Old Mar 20, 2008 | 01:10 PM
tex25025's Avatar
tex25025
Make sure that they either replaced(and checked for flatness) new heads or they machined the heads because even if they did replace bolts with studs if they didn't do any work with regard to the heads more then likely you'll still have a problem(trust me on this one).
Old Mar 20, 2008 | 04:11 PM
adambomb's Avatar
adambomb
X2 what Tex Said
When my head gaskets blew they shop tested my heads and found out that both had multiple small cracks. Now I have new heads, racing gaskets, and ARP studs so the top end should be pretty solid.
But I wouldn't worry too much its should be standard practice to check the heads.
Old Mar 20, 2008 | 05:45 PM
albran's Avatar
albran
What MODs did you have before the HG blew... stock, intake, exhaust, tuner, etc?
There are a lot of comments on here about how many STOCK 6.0s have blown head gaskets.
You may be the first stock 6.0 that I'VE read about.
I'm trying to convince myself it'll be ok to run a tuner with stock head bolts. Right now it's just not worth the worrying, possible thousands of $'s and the down time.
ab
Old Mar 20, 2008 | 06:07 PM
tex25025's Avatar
tex25025
Going custom would be about the only way that you would feel better about using a tuner on stock bolts.
Old Mar 20, 2008 | 07:04 PM
adambomb's Avatar
adambomb
albran
im not beeniebob but my truck was 100% stock w/ only a 4" Turbo Back Exhaust. It does have a goose neck hitch and the previous owner only used it to tow. the Head Gaskets blew about 2,000 miles after I bought the truck.
Old Mar 21, 2008 | 08:49 AM
benniebob's Avatar
benniebob
Mine Is Stock With 90000 Miles, The Also Replaced The Glo Plug Regulator, Glo Plugs ,some Kind Of Presure Line To The Injectors . They Checked The Heads But Did Not Replace Them. I Asked About The Heads And The Service Manager Said They Checked Out Fine. The Manager And The Tech Talked Like They Knew What They Were Doing, But Had Never Installed Studs Before. Total Bill To Ford Was About $4900.00 But Only Cost Me The $100.00.
