Sponsored by: Real Truck
Rear Diff. Leaking
Old Mar 19, 2008 | 04:03 PM
06F250XLTFX4's Avatar
06F250XLTFX4
Rear Diff. Leaking
Today I noticed a dark spot under my trucks rear axle while walking up the driveway after getting the mail. So I crawl under the truck to investigate and find that the rear diff is leaking a little bit. The truck is a 06' F250 with 25k on her. Has anyone else had this? Should i take her in for warrenty work, and how erget is it. This reason I would like to avoid the dealership is that my truck get what i consider good fuel economy (14-15city 17-19highway) and i don't want some tech reflashing my computer. Also is this just a good reason to diff. fluid to something like Royle Purple?
Thanks for the advise
Old Mar 19, 2008 | 04:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to SD....enjoy
Old Mar 19, 2008 | 05:48 PM
Lou Braun's Avatar
Lou Braun
If the rear differential is leaking enough to you to see on the ground, the leak needs to be fixed. If it is just the cover leaking this is an easy fix. If the leak if from the pinion seal you really don't want to end up paying to fix this later.
Since it is under warranty I would bring it in, otherwise you will end up doing the job yourself.
The rear end lube that Ford uses is a decent synthetic and works well.
Lou Braun
Old Mar 19, 2008 | 07:58 PM
06F250XLTFX4
thanks for the advice Lou, i think i'll swing by the ford dealer friday and see what the the service dept. has to say
pwrplay
Mar 20, 2013 09:05 PM
KoolAidMan888
Nov 27, 2012 04:44 PM
flixden
2009 - 2014 F150
16
Aug 23, 2012 07:53 PM
WorkhorseF250
Jan 9, 2012 09:18 PM
emptyd
Apr 13, 2007 11:32 AM
