Sponsored by: Auxito
4WD BRAKE ROTORS
Old Mar 5, 2001 | 01:29 PM
rob1024's Avatar
rob1024
4WD BRAKE ROTORS
Old Jun 19, 2001 | 12:03 PM
72stepside's Avatar
72stepside
4WD BRAKE ROTORS
How difficult is it to change the rotors on the front of my 98 F150 4x4? I changed the pads a little while back. That was very easy. Any help would be appreciated.
Chris
98 F-150 Lariat 4x4
74,000 miles
Old Jun 20, 2001 | 03:37 PM
Ultramagdan's Avatar
Ultramagdan
4WD BRAKE ROTORS
When you replaced the pads you were there. The rotor should have just slide off. I have heard of the rotor sticking and not coming off easliy though.
98 F250LD 4X4
Old Jun 20, 2001 | 04:30 PM
72stepside's Avatar
72stepside
4WD BRAKE ROTORS
I thought so. I didn't even try to pull one off when I had it apart before. Thanks for your help.
Chris
Old Oct 23, 2001 | 06:20 PM
Spawn's Avatar
Spawn
4WD BRAKE ROTORS
My rotors didn't come off so easy. the rotor hub had built up so much rust on the inside they wouldn't budge. two hours of hammering got them off, but left them slightly WARPED. they should have made the clearance between the rotor and the hub a little bigger.
Old Nov 6, 2001 | 08:11 PM
bufordt's Avatar
bufordt
4WD BRAKE ROTORS
Dont forget to loctite the bolts that hold the brake caliper on, I have seen these come loose and when they do they tend to tear aluminum wheels up.
Old Nov 6, 2001 | 10:24 PM
Ultramagdan
4WD BRAKE ROTORS
I make it a point to lubricate the bolts that hold the calipers on. Those can get TIGHT!! But I have had one bolt come loose since then and now regularly check them for tightness.
98 F250LD 4X4
