Sponsored by: Auxito
4.6 interchanger sohc to a dohc motor
Old Mar 19, 2008 | 08:30 AM
rhollow's Avatar
rhollow
Talking 4.6 interchanger sohc to a dohc motor
Hi my name is ron an i have a 1997 f-150 pick-up with a sohc 4.6 winsor motor in it ,an i like to put a dohc motor from a 1997 mark 8 dohc 32 valve motor.Please help me me on what to do on this interchange.
Old Mar 19, 2008 | 09:00 AM
72-F100-4V's Avatar
72-F100-4V
I know this a common swap in the Thunderbird world. I would be willing to bet that its the same ease of swap with your truck. try www.tccoa.com there are lots of people there doing this exact sohc to dohc swap just in a car. I know its not much help but is step in the right direction.
Old Mar 19, 2008 | 09:03 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Find a wrecked Navigator with a 5.4L 4V, then you will have all needed parts to do the swap!!
Old Mar 20, 2008 | 07:22 AM
rhollow's Avatar
rhollow
Hi my name is ron an i am trying to take out my sohc 4.6 winsor motor out of a 1997 f-150 pick-up truck,an take a 4.6 dohc motor out of a 1997 mark 8 an put it in my truck.Please help me on how to do this an if you know were they sells a book on interchanges like that.
Old Mar 20, 2008 | 08:44 AM
ground_zero298's Avatar
ground_zero298
the 32v 4.6 has a twin throttle body and does not make any power until the 4-5 grand range. If you did this i would recomend a quick trip around lincolnvscadillac.com for some engine info. You would probably want the 97 engine, a set of 02 conti C heads and some 03 cobra cams, along with a 80mm MAF, true duals, and a tune. Maybe a conti intake also to get the throttle body pointing to the front of the engine.
