Fired up the 460 today, rad support fit perfectly... THANK - YOU GARBZ. The measurements you supplied for eng/trans mount worked perfectly.
Ran the cam in. Lookin' like the idle is going to have to be set up a bit higher than normal for it to run. Really choppy, Instant throttle response.
All the inspiration I need to start on the body restoration.
Will post frame/powertrain pics shortly
