Gas Guage not working
Old Mar 18, 2008 | 09:04 PM
wcurdog's Avatar
wcurdog
The gas gauge doesn't work on my 81 F100 with only 325K. Strange thing is the gauge won't work from either tank. Hard to believe that both sending units could be bad. Any Ideas??
Old Mar 18, 2008 | 10:47 PM
Franklin2's Avatar
Franklin2
Hard to believe, but probably true. If you want to test it, take the wire off the sending unit, and with the key in run, and the switch set to the tank you are testing, ground the sending unit wire. The gauge should swing full scale empty or full. Then take the wire off ground and let it hang in the air. The gauge should swing full scale the opposite direction. If this works, the wiring, switch, and gauge are good, and the sending unit is bad. You can switch to the other tank and do the same test.
Old Mar 18, 2008 | 10:48 PM
wcurdog's Avatar
wcurdog
I'll give this test a try when I get back to Ft Worth, tomorrow. Thanks
Old Mar 18, 2008 | 11:03 PM
bobzdar's Avatar
bobzdar
Both brass floats were sunk on my truck, turns out both sending units worked fine...
Old Mar 19, 2008 | 01:35 AM
Stevoh's Avatar
Stevoh
Same thing with me, my gas gauges are not as accurate as I think they should be. Especially for the front tank. How hard is it to swap a new sending unit? One has to drop the whole tank I assume.
Old Mar 19, 2008 | 06:58 AM
bobzdar's Avatar
bobzdar
Or take the bed off, which may be easier if your bolts are in good shape...
