power loss
Old Oct 3, 2000 | 08:58 PM
77_F150_4x4's Avatar
77_F150_4x4
power loss
I hadent started my truck about a week and when i started it drove it the low rpm power is gone why is this? its a 77 F150 4x4 351M 4speed i use to be able to take off and tap the gas in 2nd idling and the tires would spin now it wount what can i do to get that power back.
Thanks
Curtis
Old Oct 5, 2000 | 04:50 PM
79supercab4x4's Avatar
79supercab4x4
power loss
thats interesting. when you step on it is it making any strange noises or feelings that it didnt before? or is it just running exactly the same with less power? there are so many things that could be wrong with it, its hard to say when all we know is that theres loss of power. the first thing i always do if that happens is make sure all the plug wires are tight and that the carb is squirting gas...let us know some more symptoms.
Old Oct 5, 2000 | 05:53 PM
77_F150_4x4
power loss
it runs exactly like it did but when i start off in 2nd i have to give it more gas especily in 4 high once i get past a certin rpm its fine it still idles fine and runs fine just like it use to before.
Curtis
Old Oct 6, 2000 | 03:01 AM
Superdave's Avatar
Superdave
power loss
[font size="1" color="#FF0000"]LAST EDITED ON 06-Oct-00 AT 04:06 AM (EST)[/font][p]77_F150_4x4, I had a similar problem a while back. You pushed on the gas, jerk, buck, sputter, no power, you really couldn't even get it up to road speed, and yet it idled fine. I had a tiny piece of something get sucked into one of the jets in the fuel bowl of the carburetor. A quick disassembly and cleaning had me off and running again. My truck had also sat for about three weeks not ran.
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Old Oct 6, 2000 | 06:21 AM
77_F150_4x4
power loss
Thanks if it ever stops raining and i can wash the 4 layers of mud off of it i went muddinglast night it ran good never gave me any problems ecept when i started to digging trenches i had the rear differental dragging throguh it. i will get the carb cleaned if it keeps on running like that with the way it ran last night i might not have to another thing i just thought of that it could be is the accelerator pump.
Curtis
Old Oct 11, 2000 | 03:11 AM
Superdave's Avatar
Superdave
power loss
[font size="1" color="#FF0000"]LAST EDITED ON 11-Oct-00 AT 04:11 AM (EST)[/font][p]77, "Usually" an accelerator pump failure gives you just a stumble off idle, when you push on the gas.
Superdave
Old Oct 11, 2000 | 08:59 PM
77_F150_4x4
power loss
It was the accelator pump there is a pin hole in it i am going to get a new one on it saterday i got the 4 layers of mud off only problem is i need some thing to get rid of the scratches in the paint.
Thanks
Curtis
77_F150_4x4 aka
"The BeAsT"
Old Oct 12, 2000 | 11:17 PM
uriahdeath's Avatar
uriahdeath
power loss
